주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone 6 will not charge.
Hey Guys,
Just had a quick question regarding charging on an Iphone 6. A customer brought in an Iphone 6 that would not charge, we tried a few different charging ports and the device would still not charge. When powered off, charging cable can be plugged into the phone and will boot. When plugged in the device displays a message saying please use apple charger, but the charger we were using is a Apple charger. She was using an off brand charger at one point. Anybody have any experience with this issue? Thank you in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
"She was using an off brand charger"
There's your issue right there.
She has damaged the U2 IC chip, the message asking you to use a genuine charger (even if you are) is one symptom of it, more severe symptoms are:
- Overheating
- Fast battery drain (even in airplane mode)
- Fake charging (shows charging symbol, but percentage usually goes down)
- Phone charges when on, but if left to die, will not charge, but is able to come back on with a charged battery
The only fix for this is to replace the U2 IC chip.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
I figured it would be something on the board, we have tried everything else, thank you for the answer! I appreciate it.
댓글 달기
Have you tried another battery? I have seen iPhone 6 batteries dying at a quicker rate than any other iPhone model.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I did try a different battery, it was able to boot up, but it still would not charge. :( Thank you for the suggestion!
You've already replace the charge port, so that's the only other troubleshooting step I know. Im hoping nothing on the board is bad. I have seen off brand chargers cause problems. I've seen them destroy phones, although I have seen people use them without any issues as well. Can you try a different cable and power brick just to test? Im grasping at straws at this point.
댓글 달기
Hi,you can take a moment to read this article How To Fix Slow Or Unable To Charge Problems May it can help you.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
leevancleef 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 5,399
