주요 콘텐츠로 건너뛰기
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
How to repair a loose analogstick?
so right now my xbox 360 analog sticks are all suffering from the same problem is that the analog stick is loose and wont fix its self back to center it makes it really annoying in game that my character is moving ever so slightly off in to a direction.
so my question is how can i fix a the loose analog stick?
with out any solder or having to buy a new controller.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 1개
Enciende mi control de xbox 360 pero no se conecta por Bluetooth
댓글 달기
답변 6개
선택된 해법
The drift is a very common problem but infortunately no real fix. Cosmetic issues are really the only thing that is cost effective to be fixed. You can get a used controller for like $20.00 to $25.00.
이 답변이 도움이 되었나요?
점수 5
댓글 1개:
thanks, i guess i will have to look for some old controllers
댓글 달기
For about half the price of buying a used controller here is a firstaid/rebuild kit for it:
http://secure.llamma.com/catalog/product...
이 답변이 도움이 되었나요?
점수 3
댓글 달기
You need to change the potentiometer. You can get a potentiometer in good condition, by an original xbox control.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
My hole Joystick is broken off
댓글 달기
Its always good to have spare joypads around, a 10 bucks thingy usually fits the need, also old ps1 dualshocks seem to have very durable parts
its as simple as desoldering the sticks and put in the harvested on and solder it back
most analog sticks except for ps3 and nontendo ones are the same
and the pcb of a dissected pc joypad can be used to make old joysticks like sidewinder or even the old amiga thingies to work with usb
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If it works fine, but is just loose then follow the repair guide to take it apart and put a DAB of silicone on under the stick. This way you can still take it off it you want to change them out later. That's what I did and it works perfect. Hope that helps!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
can i see bord of controller's charger
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gorillahouse 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 131
전체 시간: 90,759
