주요 콘텐츠로 건너뛰기
The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
114 질문 전체 보기
Can I reuse undamaged back cover?
So essentially I got a Z3 for pretty cheap (200 Euro) however the camera lens is full of dirt which makes the photos come out kind of bad. I was wondering if I could remove the back cover, clean the lens and use new back cover adhesive but keep the same glass cover?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
Absolutely! Just be careful not to damage when removing. It is adhered to the back of the phone and cracks easily. I would use plenty of heat and have plenty of patience when removing the back. I would also check ifixit for a guide, or youtube!
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks I'm going to go order the adhesive tonight.
댓글 달기
I would recommend replacing the entire back glass after removing it.
They are dirt cheap to buy and saves cleaning it/adding new adhesive.
You can probably buy the back glass with adhesive not much more then the actual adhesive.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Hup 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 8
전체 시간: 393
