주요 콘텐츠로 건너뛰기
27" 화면 2560 x 1440 픽셀 해상도 Thunderbolt 및 MagSafe 케이블 부착물
160 질문 전체 보기
Where exactly on the hinge mechanism is the product serial number?
I read here that the Thunderbolt Display has the product serial number printed on a sticker on the hinge mechanism. Where is it exactly? I think the sticker may have been removed from mine.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
Turn the display on its back then look at the bottom of the foot
Thanks Dan. I know that the serial number is printed on the bottom of the foot. My question is about the hinge mechanism.
댓글 달기
답변 2개
선택된 답변
this should help
https://support.apple.com/library/conten...
해당 답변은 도움이 되었습니까?
점수 4
댓글 5개:
Jim - That's what says is missing. Go back to your link FULLY and read it all. See Dan's answer.
@mayer Sorry didn't realize there was a separate serial number for the hinge
@beaverme this video shows how to remove the the hing and at 47 seconds in you can see the serial number on the hinge assembly itself
https://www.youtube.com/watch?v=e4kHw-5m...
sorry for the earlier confusion
Nice research Jim
Thank you @jimfixer. The video shows an iMac but it seems reasonable to assume that the Thunderbolt Display is marked is the same place. Unfortunately the hinge on my Thunderbolt Display does not have that label.
댓글 달기
The hinge is where the foot connects to the display. You'll need to remove the foot to see it. Its' a real pain to get to.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Removing the stand wasn't too tricky but I cannot see a label on the visible part of the hinge mechanism.
mmm .... Was it a little warm when you bought it ;-)
I'm wondering if the s/n shows up under the hardware profile for the display. That's the only other place I can think off other than pulling off the display assembly off and looking on the logic board.
댓글 달기
귀하의 답변을 추가하세요
Lee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 579
