주요 콘텐츠로 건너뛰기
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 질문 전체 보기
My iPad screen went black
I've dropped my iPad on the carpet by accident and the colors where disordered with a lot of green. I've also had this problem before and managed to fix it by gently tapping the border on the down side with a hammer. So I did it again. Insead this time my screen went black. I can see it is still working because if I stay in a dark room and press the Home button the screen will light up. Do I have to get the display replaced or is there a solution?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Have you tried the home button lock button combination?
If so, the cable to the LCD may need replacing, or the LCD may need replacing, if that doesn't work, the back light may be busted, and that requires microsoldering.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Yes, I've tried it too. Apparently the black light is okay and it's an LCD problem. I will go today in a service to get it changed...
But thank you so much for trying to help me!
댓글 달기
귀하의 답변을 추가하세요
biancadaraban11 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 120
