주요 콘텐츠로 건너뛰기
모델 A1502 / 2.4, 2.6 또는 2.8 GHz 듀얼-코어 Intel 프로세서 / 2013년 10월 출시
552 질문 전체 보기
Liquid damage - is it the battery or the logic board?
H i,
there was coffee spilled on my MacBook near the fan. It still works fine with the AC adapter, but the battery seems to be broken. Also, the battery symbol says that the battery has to be exchanged.
My questions:
- Do you assume it's rather the battery or the logic board that is broken?
- Sometimes (especially after using it for a while) the MacBook seems to work slower or have glitches. Why do you think is this?
Thanks a lot in advance,
Sebastian
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
I would dissasemble and check it, no point in risking it letting corrosion build up.
Clean it all with 99.9% isopropyl alcohol, and a toothbrush.
Or go for the more professional approach and get a shop with a good ultrasonic cleaner etc. :-)
I would also replace battery if it has been effected.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I had the same happen. I had to replace the keyboard, battery, and logic board. Probably cheaper to buy a new one. I am in Canada and it was $1100 to replace those parts.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
sebastian 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 450
