주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone 6 not turning on - tried almost everything
Hey iFixit Team,
I purchased an iPhone 6 which was not turning on. It had a cracked screen and once opening up I could tell the battery had been replaced.
I replaced the battery and screen with genuine parts from an iCloud locked iPhone 6. I got the phone turning on but it was running slightly hot and draining faster than normal.
I restored the software from recovery mode and the problem persisted. Now the phone does not turn on after I left it dead for a while. I know I could probably get it to turn on if I put a charged battery in but I would like to fix the root cause. I have a feeling it might be a motherboard issue but would like to seek clarification and advice...
I have careful performed the screen replacement and reinstalled the battery with the proper apple adhesive strips so I should be able to get a replacement from apple if I can't get it fixed.
Thanks again,
Nick
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Your answer lies within your question "I got the phone turning on but it was running slightly hot and draining faster than normal"
And now the battery has died it won't charge.
These are clear symptoms of a damaged U2 IC:
- Fast draining battery
- won't charge when dead
- phone getting hot
You need to replace the U2 IC, and this should solve your problem, this requires knowledge and the equipment to do microsoldering. :-)
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thanks for the quick reply! That doesn't sound like a repair I could perform or do you think it is worth learning? I might see if apple can replace it..
It requires pretty expensive equipment, decent microscope, decent soldering iron and reflow station, decent solder and flux, etc.
You can try Apple and see if they will replace the device.
Thank you, will try apple and let you know how I go!
댓글 달기
귀하의 답변을 추가하세요
nickb1994 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 243
