주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
Mac not charging after minor water damage
Hi guys.
I've got a friend's mac that got given to me to have a look at. The mac at first was not starting up at all after a water spill.
The laptop was then disassembled and thoroughly cleaned with alcohol to ensure there was not water residue left on the logic board.
I replaced the battery, and the DC jack. After replacing the battery the macbook started up without any problems.
My only problem is that, after trying 3 separate chargers (known to be working on other macs) the light on neither chargers will light up!
I don't have ANY colour light showing. Any one able to point me to what chip might needing to be replaced (if any) or if there's any tricks with the macbook chargers? I'm not too savvy with macs I repair windows laptops mainly.
I've cleaned the logic board about 3 times now without ANY sign of corrosion at all. Every chip looks to be fine (well as far as what my eyes can see).
Looking forward to a reply, peace.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
Trying to tell you exactly what chip needing replacing is toooo vast! It could be the chip, resistors ,caps or inductors or even shorted traces that require jumps. You need to search the net for boardview and schematic for your board and check for short to ground with multimeter youtube can help if you look right. No light on the magsafe usually means the one wire over voltage is not working , feel around on the board and see also if there is area that is super super hot obviously this means the circuit is shorted. That's all I can do this is a very simple answer to a very in depth answer. Good luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
sxcchaldo69 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 5
전체 시간: 123
