주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
Why will it not turn on?
Hello. I am about to purchase an Apple iPod Classic 6th Generation in order to fix it and sell it on EBay. The seller says that the back is very scratched up (no dents) and it will no turn on. Why could this be? Could it be because the battery is broken and needs to be replaced? Thanks and please help me!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 3개
선택된 해법
It could be a collage of problems. Anywhere from the battery, to issues with the logic board
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
See the concept of "Pig in a Poke": https://en.wikipedia.org/wiki/Pig_in_a_p...
You might have better luck with a "Mystery Box", http://www.ebay.com/sch/i.html?poi=&adpo...
이 답변이 도움이 되었나요?
점수 4
댓글 달기
I'd be wary of any nonworking iPod you buy off eBay. I recently purchased a (supposedly working) logic board off there and lo and behold! It's giving me all sorts of headaches trying to get it to work with my iPod. The person could easily have cobbled together a bunch of nonworking parts after salvaging a bunch of broken iPods. There could be damage they're not telling you about (from water, dropping, previous amateur attempts at repair).
It sounds like the problem is the battery, but it COULD be the logic board being broken at the place where the battery's cable connects to it.
You can order it, but make sure you can return it and get a refund just in case & check out the internal parts quickly to assess the damage so you return it in time.
ALSO: if it's simply that the battery is dead, the iPod should still turn on when it's plugged into a computer or a USB to outlet converter. If it doesn't, it's not just the battery, in which case I'd be very wary. Replacing a logic board would cut severely into potential profit. Ask for pictures from the seller to verify their words if you haven't already.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Luke Thompson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 178
