주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 4는 2014년 10월에 출시된 셀룰러 스마트폰입니다. Galaxy Note 4 모델 번호는 SM-N910, SM-N910A, SM-N910T, SM-N910V 또는 미국 버전은 SM-N910R4입니다.
How to fix samsung galaxy note 4 wont run?
When I turn on my Note 4, yes it will still display a logo for samsung, but it will not run until it will display the menus. it will just show the "blink" sumsung logo or word. Please help me fix this one, i baught my phone in Thailand.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
Can it boot up if connected to a wall charger? Did this take place after trying to apply a system update? Have you tried to hold any button combinations to try to boot into recovery to perform a factory reset? Has the device been dropped or had any other incidents?
Had same problem took to Samsung galaxy repair person ,told me my phone was a clone and couldn't do anything to it.watch out for this when you bye one from a person or ebay.i know what to look for now
댓글 달기
답변 3개
선택된 해법
Hi Rodel
Try to restore to factory settings.
1. Turn off your Galaxy Note 4.
2. Press and hold Power, Volume Up and the Home button until you see Recovery booting in blue at the top of your screen. Release the buttons.
3. You'll now be in Recovery Mode. Use the volume buttons to scroll up and down and the Power button to confirm. It's not a bad idea to wipe the cache partition while you're here, but it is not essential.
4. Scroll down to Wipe data/Factory reset and press Power to confirm.
5. Scroll down to Yes and press Power to confirm.
6. You'll see a notification in yellow at the bottom of the screen to confirm the reset has been completed. Scroll to Reboot system now and hit Power to confirm.
7. Your Galaxy Note 4 will now reboot. Once it has rebooted, you can restore your apps and data.
Let me know if this helped.
Thanks
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Thank you for your help, I already did it for several times but it still not work in my phone, it just display the logo of samsung. What can I do next for this? please help me.. Thank you a lot.
its stuck @ blue thing on the top it neither moves from there nor restrarts
댓글 달기
you need to flash it
follow this guide to do it
http://forums.androidcentral.com/ambassa...
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
good day! I already downloaded the ODIN and the copy of ROM, but when I plug in my Phone to my PC, the ODIN cannot recognized it. Aside from that when I press and hold home+volume down+power, chinese langauge are displayed and I cannot understand.
I have also a problem on how can I put my phone into download mode becuase it is korean made. I cant understand and locate what button to press to put into silent mode.
댓글 달기
It seems that you device has stuck in boot loop. The most common and popular method is hard resetting your device.But it seems that hard resetting has not worked for you.So, try flashing your device after downloading the correct firmware file for your device. Since you have bought the device from Thailand you need to check if the device is using and international firmware or country specific firmware.Here you can have complete guide ++samsungodin.com++
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rodel Domdom Minoza 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 45
전체 시간: 27,681
