주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 1.8GHz 듀얼-코어 Intel Core i5 (Turbo Boost 최대 2.8GHz)
371 질문 전체 보기
Water damaged MacBook Air with screen flicker
Hello everyone,
I am trying to repair my macbook air, which had become water damaged. Thankfully only a bit of liquid went through the vents of the macbook, and got to where the display connector area is on the motherboard. I took the macbook apart as soon as possible, and cleaned it with alchohol and let it dry.
The macbook works fine, no issues except now the screen flickers. The screen stays on, and you can faintly see things on the screen but the whole backlight randomly goes off. I am wondering what would I need to replace? Does it look like I will need a whole new display, or a LVDS cable, or maybe something to do with the logic board?
Here are some pics:
The water spill got through these vents:
This is how it looks like for display connector area
The rest of the motherboard is fine, no liquid got there
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
I have dealt with this issue 4 - 5 times with water damaged macbooks and replacing the entire display assembly was the only fix that worked .
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I dont think it could be the screen though, since its always on. Its just the backlight flickers from super bright to super dim
댓글 달기
you need to clean away any corrosion which i can see some of between the microchip amd the black squares (capacitors) in the top right of the second photo. If possible remove the board completely and give it an ultrasonic clean in alcohol. IMHO Repairable …. Louis rRossman on youtube is a good start for information
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
schmaltz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 3,791
