주요 콘텐츠로 건너뛰기
A 4 Amp corded power drill released in June 2014 by Black and Decker. The corded device is a part of the Matrix Quick Connect System which enables various attachments.
How can I switch the direction on the drill?
I need to unscrew a misplaced screw but I don't know how to switch it into a reverse position.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 2개
please tell me how the reverse mechanism works in bosch gsw 450re , because it isnt working in my machine ..
How to take a screw put w/ a 1/4in single speed drill by black &decker
댓글 달기
답변 2개
선택된 해법
In order to change the direction of torque, fully toggle the switch above the trigger into the alternative position.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Hi does a black and decker bd163va have reverse.or what is the black round button for near trigger
댓글 달기
I have a domestic 450w Black & Decker electric drill that does not have a reverse switch, yet it is turning anti-clockwise. Mind you, I lent this driller to someone who returned it long ago, but now I wished to use it in lieu of the other two that I have and discovered that it has started to turn anti-clocwise with the result that the chuck unwinds. Please can i repair it as it is adequate for me.
Update (02/09/2017)
I do not know if he repaired it or not, because he passed away.
Update (02/09/2017)
Re Black & Decker drill, it only has a common switch and a sideway button which when pressed while drill is functioning will render drill functioning automatically. Again, please anyone with a correct answer? Thanks beforehand.
Update (02/09/2017)
Hi Mr Edgardo Gutierrez thank you for your answer. But my drill has a common switch.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It is possible to change the direction by reversing the brush connection which will be internal to the machine. Need electrical knowledge to do so.
댓글 달기
답변을 추가하세요
Tyler Yurina 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 9
지난 30일: 51
전체 시간: 49,582
