I have a timing belt possibly needing replaced where do I start?
My car will not stay running and it seems like it is the timing belt issue but I don't k of where to start
좋은 질문 입니까?
좋은 질문 입니까?
Can you be more specific about how the car runs when it does run? Does it lack power is the exhaust glowing red when it does run ?Is it easy to start or hard and when it runs at an idle does it run smooth or misfire. Is there white smoke coming from the exhaust? is you coolant level ok or is it down does the car overheat when it runs ? The problem is not in the timing belt as this car doesn't have a belt . It runs a timing chain and its quit rare to have an issue with it. You can check by getting a timing light and checking your timing
Hope this helps
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 75
