주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
Black Vertical lines after cleaning LCD
Hi, I was wondering if anyone has done OCA repaid on iPhone 5S LCDs. I have a problem that I remove the glass and it's fine but as soon as I clean it I get black vertical lines. Anyone knows why?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
I am pretty sure you cracked LCD. I used to have a lot of this issue as well. Sometime iPhone LCD didn't show cracked right a way.
- for iPhone, better remove polarize most of the time. for me i replace polarize for almost every time. iPhone 5/5s LCD can't handle too many pressure. so try to take time and don't give too many pressure when you clean up.
There is polarize glue remover (8222 250ml Polarizing film remover) but can't buy anywhere in US at the moment. Most people use blade.
I would say 80% LCD cracked when you take frame off from the phone. (for 6 and above model)
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
hi mate. yeah, i was thinking its cracked or the flex, cant buy any of the machines here in Australia. mine came from china. insted of using the glue remover i use a plastic blade to clean the glue seems to work now. iphone 6 and up can handel the glue remover but not the 5 series. thanks for the help, appriciate it. it ccomfirms what i was thinking.
You are more than welcome. Using the 8222 remover is a magic. Only 20 sec and it peel it off and nothing left. You can ask OCA Master from China. The manager speak English.
댓글 달기
답변을 추가하세요
hamied202010 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 142
