How much does it take to buy a new screen 3ds
I sat on my ds how much does it take to replace a screen
Update (02/18/2016)
좋은 질문입니까?
좋은 질문입니까?
Depending on which screen you broke and how ambitious you are the screen repair tutorial is here Nintendo 3DS XL Touchscreen Replacement
and the replacements for them are here
[링크된 제품이 누락 또는 비활성화 됨: IF258-025]
Hope this helps
이 답변이 도움이 되었나요?
Upper screen
so then you can purchase the screen for about 25 dollars and follow the guide in the answer above to fix it. If you want someone to do it for you then you should check your area for repair services near you
So I took apart the bottom and replaced the screen but now my select button does not work
You may want to take it apart again to check the connections on the buttons. something could have come apart when you were putting it back together
ok thanks for that I will check
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 1,795
