주요 콘텐츠로 건너뛰기
Can I use paper with extra length (327mm/1000mm for example)
Hello everyone
I m the lucky owner of an epson L1300 and I would like to know how can i print on extra long paper (327mm/ 1000mm) is it possible ? Or is it too long ? i m not talking about the width as the epson l1300 takes A3+ my question strictly consern the maximum length i can use
Thank you in advance
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Pull up the printer's settings/properties window. You can select paper size from a list, but you can almost certainly set a custom paper size. Width is of course limited by the width of the printer, but you can try setting the height/length to whatever value you'd like to use and see if the printer driver will accept it.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
pvpclement 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 112
