주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Screen not staying on
iPad mini a1490, glass and LCD both repaired. When I try to turn the iPad on, the Apple logo comes on, then it goes to a black screen. I let the battery run down and plugged it in. The charging indicator comes on for a second then it goes to a black screen. It's like the screen is shorting out..... Help please
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
Same issue & model! But my device has never been repaired, it stays powered, I hear the sound when I plug in power, and if it is dark enough I can see that the backlighting is on. On occasion, especially if the device is cool, the screen and touch respond well enough, but as soon as it warms up the screen goes black. I can turn off the device if I'm lucky and swipe in the correct area. What needs to be repaired and is it even worth it?
댓글 달기
답변 1개
Is the device staying powered on? Do you hear any lock sounds or notice any activity when the screen goes black? Does the device boot loop or just turn black?
If the device is boot looping you may have damaged the gas gauge components that are next to the battery connector when using your tool to disconnect it.
Let me know what you find!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
marchinds 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 5
전체 시간: 203
