주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
TouchID not working even after replacing metal plate. Error 53 solved
After replacing display I used to get error 53 which is resolved by replacing metal plate (ribbon). Even after solving ribbon issue and using original home button and parts my touch id is not sensing my finger print. When I go to add finger print in settings it does nothing. Doesn't sense my finger.
Already tried dusting off the contacts thoroughly but no avail.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
Have you tried factory restoring the device with the original home button? (this could be very risky if the button is damaged or it is not connecting properly.) Are there any signs of water damage in the device? Also how do all the connections look inside? Have you tried cleaning the connections with a ESD safe brush?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
No water damages at all. Cleaned connectors with soft tooth brush.
Will try factory reset later today and hope that fixes it.
Did factory reset but touch id is not sensing my finger .
댓글 달기
귀하의 답변을 추가하세요
Chet Patel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 181
