주요 콘텐츠로 건너뛰기
This is a 4V Lithium-Ion battery, cordless, rechargeable screwdriver.
Why will my screwdriver not charge when plugged in?
My rechargeable screwdriver will not charge when it is placed in the charging bay. The LED light is not on.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Hi Mark,
First, you should check that the charging bay is plugged into a working outlet. If so, inspect the charging contacts located in the charging bay near where the rear of the screwdriver sits. Be sure there is nothing blocking these contacts from making full contact with the contacts on the screwdriver (i.e. dirt, debris etc.). Also, if the contacts inside of the charging bay are jammed, bent or damaged in any way, this will affect the charging capabilities of the charging bay. Consult the device repair guide for steps on disassembly of the charging bay for repair and/or replacement of the charging bay contacts if damaged. If the contacts of the charging bay are making full contact with the contacts on the screwdriver, consider replacing the screwdriver's battery. Steps for replacing the screwdriver's battery can be found in the device repair manual.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Did You ever solve this problem was it the batteries
댓글 달기
답변을 추가하세요
Mark Mallory 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 38
전체 시간: 9,722
