주요 콘텐츠로 건너뛰기
This is a 4V Lithium-Ion battery, cordless, rechargeable screwdriver.
Why will the screwdriver not turn when I pull the trigger?
The screwdriver will not turn when I pull the trigger. The work area LED is coming on.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Hi Mark,
According to your description, the work area LED light is coming on when pulling the trigger. In result, this indicates that the screwdriver battery has not yet been depleted. First, remove any load from the screwdriver (if any) and test for rotation again. If the screwdriver rotates after removing the load, it is possible that you are over-torqueing the screwdriver; select another torque setting by rotating the torque selector located just behind the bit socket. If the screwdriver does NOT turn after removing the load to the screwdriver and pulling the trigger, consider opening the device and inspecting the brushes for the electric motor internally. Consult the device repair manual for detailed instructions on inspection and replacement of the brushes.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Mark Mallory 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 64
전체 시간: 2,404
