주요 콘텐츠로 건너뛰기
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
160 질문 전체 보기
How can I remove stripped Torx T2 screw?
I am using Japanese 3G vita (PCH-1100) and I was going to replace the 3G networking card that shipped from Europe. (to elimate SIM Lock.)
but unlike other reigon vita's, mine have a two of Torx T2 screw is tighten in 3G card.
so i bought dirt-cheap T2 screwdriver from local store and this thing stripped the screw :(
how can i take out this stripped T2 screw?
I tried rubber band method / soldering screwdriver to screw / put loctite 401 to screw head and stick screwdriver in to stripped head but none of this trick worked.
can anyone give me a advice ?
p.s: I got a spare screw so I don't bother if screw is destroy during removal.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Drill it then use vise grips, an easy out could work . Depends on how bad it is. Make sure the drill bit you use is of good quality
댓글 달기
답변 3개
선택된 답변
Try screw grab I have heard very good positive feed back on using it. Here is a link of the product.
http://m.skygeek.com/screwgrab.html?utm_...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
I solved the problem.
I used PZ-57 Precision Screw Piler to extract those stripped T2 torx screw.
room was enough to fit that Screw Piler.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks for this. I was trying to install a psvsd in mine and quickly learned that T2 screws are the devil.
댓글 달기
this will depend on you having a Dremel and confidence what you will need to do is using the dremel make a grove for a flat head screw driver
i sugest stopping every few second so you do not over heat anything
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I don't have a dremel right now. I'll try after bought one.
btw, is there a screw extractor for this kind of screw?
because I have to pay nearly 170 dollars for base dremel set.
댓글 달기
귀하의 답변을 추가하세요
Dosik Ham 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 42
전체 시간: 2,623
