주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
Upgrade Logic Board to newer low power board
I love the fact that my Mid 2010 Macbook Pro has accessible components that the newer MBP do not. With my 500GB SSD and 16GB Ram, the computer simply flies on the toughest apps. However, I don’t like the fact that the older boards burn through battery power so quickly. So..... I’d like to upgrade my logic board to the newer low power board. Can that be done?
Update (02/21/2016)
Back when I bought the MBP in 2010, I unplugged a 4 GB MBP at the Apple store and left it turned full brightness on it side by side with my upgraded 16MB MBP. They both ran the battery down at similar rates. I’d like to been able to run mine for 8 hrs using the newer board, but am not sure the connectors are the same, and whether everything will fit with minor mods
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Sadly, there is no low power logic board which you can fit into your old case.
Over the course of the time Intel and others have worked hard on lowering the power needs for different components. Apple has also worked hard improving the batteries used in its systems. All of this work is seen in the MacBook Pro retina series. It is not transferable to your older MacBook Pro.
Things you can do to gain a few minutes here and there:
  • Use lower power RAM and use less of it. I would drop down to 4 GB.
  • Next, I would lessen the size of the SSD (128 GB) and make sure it was a low power unit again the density of the SSD will use more power.
  • Next, I would replace your battery with a newer unit. While you can find some batteries with a larger Ah the age of the battery is more important here.
  • Next, I would focus on what is running using Activity Monitor. Lessen the background tasks and not run more than one application at a time.
OK, what will this buy you? Not much! If you really work hard you maybe able to get 5 minutes more of up time.
Frankly, I don't think its worth all of the trouble and besides, your system may not be very useful being stripped down to such a state.
What we do is use external battery packs to lengthen the use time. Our field engineers are often located at sites that just don't have power available or can stand still long enough to let there systems charge. We have over 250 people in the field all with older 15" MacBook Pro's.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
가장 유용한 답변
That 16 GB of RAM looks really fancy and flashy. And just how much of it do you think you really use? Try pulling one and see if you can discern any performance decrease and note how much longer your battery lasts.
How much is the battery life reduced by increasing RAM?
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Mike Wong 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 125
