주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
screen unresponsive/goes crazy HELP
All of a sudden, my iphone 6 plus screen get either unresponsive, or when I am able to slide to unlock, it goes off on its own and goes crazy like opening apps texting random letters etc. Would replacing the screen and digitizer repair this or is it software??
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
Is commonly a defective digitizer. If the phone is less than one-year-old, head on over to the Apple Store and they'll likely fix it for you.
Otherwise, and it replacement LCD assembly is very expensive. In addition, there is a glue perimeter reading between the phone in the LCD assembly for the sake of the 3-D touch. If I could read the repair difficulty below one out of 10 I would. :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My iphone 6 developed the crazy touch screen problem about 2 months ago. I searched the forums and realized how common it was. I tried the rubber tape under the metal cover that holds the connections in place but it didnt work for me.
I tried to think of anything I had done that might have caused it and the only thing I could think of was downloading a film from sky store.
My phone is a 16 gig and on checking the memory usage 12.8 was full including 4 used by the sky store app which included the film. I deleted the app which took the memory usage down to 8.8 and hey presto totally cured !!!!!!!
It probably wont cure everyones problem but it is 100% what happened with my phone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
What is wrong with my iphone 13
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Pls help!!!!! I own a iPhone 6s and it is going crazy, it starts to type letters, open apps by its own and even dial random numbers and call them. Pls help
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Junior Morgan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 6
전체 시간: 7,216
