주요 콘텐츠로 건너뛰기
The Sony Xperia M2 is mid-range 4G Android smartphone produced by Sony Mobile. Available - May, 2014.
34 질문 전체 보기
no sim no service any advice
My phone experia m2 keeps coming up no sim no service any advice
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
Hi, ik heb hetzelfde probleem. Het schijnt een bekend probleem te zijn bij de experia m2. Je kunt een paar dingen zelf proberen.
1-Haal simcard eruit en plak op de witte kant een 10 tal reepjes plakband, dit zorgt ervoor dat de simcard tegen de contact punten wordt aangedrukt.
2- je kunt een nieuwe simcard pcb kopen en deze zelf er zetten of laten zetten. https://youtu.be/wADy76yTen0
Succes,
Danny
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi , i have the same problem . It seems to be a known problem with the experia m2 . You can try a few things yourself.
1 Remove simcard and stick on the white side 10 strips of tape, this ensures that the simcard at the contact point is pressed .
2- you can buy a new simcard PCB and fix yourself. Make sure you buy for the right type for example D2303, D2305.....
Success,
Danny
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My phone experia m2 d2302 any sim card insert no service and emergency call only show how to sloved pls tell hardware solutions
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Michaela 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 3,850
