mobile network not available
worked this moring when calling to doctor but not working now at 3pm still can't get work.
좋은 질문 입니까?
좋은 질문 입니까?
Some Simple Solutions:
Solution#1
Solution#2
Set your mobile network to automatic .
Solution#3
Update your phone software.
These solution will probably fix error while searching for networks.
Hope it helps.
해당 답변은 도움이 되었습니까?
restart phone,
if not get network check airplane mode is ON, if it ON then turn off it
still not have network, check imei by dialing *#06#
if it error rewrite imei code
if it not error
need to check network connection part
해당 답변은 도움이 되었습니까?
Which sim do you have. go to setting and mobile network and try manual search for mobile network. and look for your network and register it. Or go to setting sim management and then disable sim and then again reactive it. or lastly remove sim and insert again.
해당 답변은 도움이 되었습니까?
SIM cards can go bad, if all else fails, go back to your carrier store.
해당 답변은 도움이 되었습니까?
I had the same problem but I finally figured it out!! I went to settings/ cellular network/billing cycle. If “set data warning” is on, turn it off. If “set data limit” is on, set it unreasonably high just in case (15.0) and turn it off. The reason my Cellular data wasn't working is because it was set to turn off when the limit was reached! Hope this helps you too!
해당 답변은 도움이 되었습니까?
My phone doesn't work any application
Not working
Whatup
Play store
Time and date problem issued
Check you're APN. If you have certain cellcarrier, then your APN may need configured. I have att and had this problem to and shutting down phone didn't help. It kept doing it. Finally someone told me about APN and haven't had the issue since.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 47,932
댓글 14개
My phone would not turn on
wilmab 의
My network not working how to fix
Letisha Palmer 의
How do I get pass my google count to open it? My blue sell phone?
brodersonjulie 의
Mere moile ka network cale ghe Hi
kamran aman 의
My data is not responding, I cannot browse, look Facebook. Pls to me how to set it up on blu phone vivo 5 mini
Ginette Mande 의
댓글 9개 더보기
