주요 콘텐츠로 건너뛰기
인간-동력 이륜 교통수단. 관련 페이지 섹션에서 귀하의 자전거, 특정 부품 또는 문제 해결 위키를 검색할 것인지 결정하십시오.
153 질문 전체 보기
Putting back wheel back on.
Had a flat. Took the wheel off and took it to bike repair to fix the flat (it was well worth the $7.50).
I'm putting the wheel back on. Is there anything in particular I need to know about getting the alignment right?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
I assume you're talking about the rear wheel, since the front is pretty easy. One a bike like this, after you get the chain back on the sprocket and the axle back into the drop-out slots (make sure all the washers and such go back onto the correct side of the slots), you need to do three things at the same time:
1) tension the chain by pulling back on the wheel,
2) align the wheel such that it's centered between the frame forks, and
3) tighten the axle nuts.
Generally, you pull the wheel straight back with one hand and slightly tighten the axle nuts with the other. Then you can give it a spin the verify the alignment, and touch the chain the verify it's tight enough (leave just a little bit of slack), and if it's all good, you tighten the nuts fully (tighten firmly, but don't over tighten them).
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Oh, and since this bike has a 3-speed hub, don't forget to finally attach the hub bracket to the clamp on the lower fork leg.
댓글 달기
귀하의 답변을 추가하세요
Cheri 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 2,230
