주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
My iPhone 6 has lines and black spots all over the screen
So I dropped my phone this morning and the screen slightly popped off so I pushed it back in and there are lines that around colorful and are horizontal and vertical are all over my phone. And when a press on it the lines change and there is a huge black spot too. Do I just get the screen fixed? Is there also something wrong with the motherboard too? please help me out
Update (02/23/2016)
These are pictures of how my phone looks too
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 18
댓글 달기
답변 5개
선택된 답변
Is the phone functional in all other ways camera, app functions, music play . Test it for function . Does it seem to be running warm or hot or differently in any way . if all seems fine except the screen odds are that you can replace the LCD and your phone will be fine . There is also the off chance that the cable has been partially dislodged and reconnecting will fix the problem but most likely the LCD is damaged . Hope this helps
해당 답변은 도움이 되었습니까?
점수 7
댓글 8개:
After seeing the photos you posted it looks like testing functionally is not an option. but I would still replace the entire display . If it doesn't work you can always resell the display on ebay
Thank you so much for helping me out! This has happened to me before too but the screen wasn't so bad. I really appreciate it!
I have the same thing with my iPhone 6s it has the lines and yellow and black dots but the black is covering the yellow dot. I don't know what to do about fixing it. My iPhone is not ready yet for a up grade for a new phone. It is hard to read my text massages. I don't want my iPhone 6s to dietary all. What should I do about my iPhone 6s? I am haveing trubal seeding the pitcher of my iPhone 6s what it looks like know.
my phone has coloured lines and black patches but i cant use my screen at all and it disabled my phone too
Thank you this happened to my phone too however i can still use the phone, will the lines and the black dots grow, will the problem get worse or can i just leave it? thanks
댓글 3개 더보기
댓글 달기
Probably the front panel needs replacement. You have guide here on IFIXIT, good luck!
해당 답변은 도움이 되었습니까?
점수 7
댓글 3개:
Thank you for helping me out :)
I think am gating a Prepay phone. Unttill my iPhonere 6 is ready for a upgrade to get a new Smaert Phone or something els I don't know yet.
This was a very unhelpful answer, selling it just like that is unhelpful and useless
댓글 달기
Hi i recently dropped my iphone 6 like the picture showing i have lines on my phone and black dots but i also keep getting a message on the home screen there is a sensor issue with the phone but its responding to my touch only on the bottom half of my screen the home button has stopped working before i dropped the phone and i cannot unlock my iphone because my passcode has numbers at the top of my screen, will replacing this screen fix the issue as the screen is completly cracked and parts of the screen are missing at the top ?
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I have this problem on my phone too what shall i do?
댓글 달기
So i dropped my iphone and know i can’t even get into it cause there is black spread all around my phone and on the top half of the phone there is vertical lines then on the bottom half it’s just glitching out and idk what to do with it. Do any of ya’ll know what to do?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
my phone is the exact same as the image after i dropped it. if i get this repaired will i lose my data
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Amrin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 24
30일 전: 88
전체 시간: 97,541
