주요 콘텐츠로 건너뛰기
The Acer Extensa 2509 features an Intel Celeron N2930 processor with Intel HD Graphics.
11 질문 전체 보기
Why is my cousins laptop screen turned white?
Me and my cousin has been trying to fix a Acer laptop. Every time we turned on the laptop screen is always on white and lines down on the left side of the screen. We removed the battery and hold down the turn on button more than 60 seconds. We tried shutting it down but it doesn't work at all.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
If the screen is turning on the lighting is ok. So it is an image signal issue.
You should check the flat cable on the back of the screen, to ensure that is seated properly.
But when I read twice your description I have noticed you mention some lines in a corner of the screen, so the problem is related to the t-con of the screen.
The easiest fix is to replace the screen (same size and technology).
Hope this helps.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jade Harrison 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 111
