주요 콘텐츠로 건너뛰기
캐니스터, 로봇 및 직립형 진공 청소기 수리를 위한 단계별 안내서.
1554 질문 전체 보기
Canister vacuum no suction when brush attached Bosch
1450W 12 amp vacuum
BSG81396UC Premium Prestige Canister Vacuum Cleaner
I was hoping you have advise my vacuum works fine suction etc until
I plug in the hose with peered brush attachment Then there is no suction at all . Hose, filter , and bag are clean and free of clogs
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
Well you either have a clog you don't know about or you aren't switching the suction to the hose. Take off where hose starts and see, if you have suction there then you know it's the hose. And if you don't have suction then it's somewhere else. Pretty simple
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
After checking proper suction by removing the hose, inspect the brush for potential obstructions like hair or debris. Remove the brush cover for a closer look. Additionally, run your hand along the hose to check for punctures or leaks, which can significantly reduce suction. Certain models feature adjustable brush heights for various floor types. Confirm that the brush height suits the cleaning surface, as an incorrect setting can impact suction.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
DPWCT 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 114
