Nexus 6p screen scratched
I scratched my screen 6p nexus in the technical service of huawei they change the LCD screen + Frame + 188 € but in my case is only scratched the screen. they can change only the glass and make cheaper repair?
좋은 질문 입니까?
좋은 질문 입니까?
While it is technically possible for them to replace only the glass it would be more time consuming than it is worth. Since the glass and lcd are bonded on most phones, replacing only the glass would require then to separate the panels and reglue a new piece of glass. This can end up breaking the LCD and when it does work the results usually are not as good as new. In the end it is more reliable for a big company just to replace the whole unit, however if you were to replace the glass yourself you could save some money. From someone who has replaced the glass only on a galaxy note 2 though, I would say it isn't worth it if you are going to be using the phone as your daily driver.
해당 답변은 도움이 되었습니까?
legofiend96 is right, well, you may buy a replacement online and have someone to repair it for you, that would be cheaper than sending it to Huawei service.
Replacement: http://www.etradesupply.com/huawei-nexus...
해당 답변은 도움이 되었습니까?
Baking soda can serve as a handy phone scratch remover. Here's how this remedy works:
* Stir until it forms a thick paste.
* Apply the paste to a clean, soft cloth and gently rub in a circular motion on the phone's scratches.
* After this, wipe your screen with a fresh, slightly dampened cloth to remove any excess.
해당 답변은 도움이 되었습니까?
PSD to WordPress, We Deliver high Quality Conversion Services to Our Clients.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 2,557
