주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Big burn marks iPhone 4s
Hello IFixit,
A customer came by with his Iphone 4s and showed me something I have never seen before:
http://postimg.org/image/4975dze31/
He explained: it started with a little bit in the corner and just increased bit by bit.
It is still functional so touchscreen is working normally.
Can anyone explain what this is and where it is coming from?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Those look like pressure points, most likely being applied to the back of the screen. If this is a replacement screen, it may have previous damage that is just now showing up. The fix is a good front screen assembly, and just make sure everything behind the screen area is in order, so this does not recur.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I also do not know what caused this. Pressure points looks nothing wrong with, Also the back of the screen look perfectly fine. Yes it was a replacement, so it probably increased with time.
New Iphone 4s LCD assembly fixed this problem.
댓글 달기
Iwant screen loock free
Update (05/26/2016)
Iwant screen passwood
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Job Wintjes 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 565
