주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Camera no longer works after display exchange.
Hello,
I have changed the display on my iPhone. 6 After starting the iPhone, the front AND back camera stop working.
I have a hard reset performed, and have my iPhone reset to factory settings.
Now i have baught and installed a new front and back camera, but it still doesn't work.
Someone has a solution?
sorry for my bad english :D
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
가장 유용한 답변
Hi Manuel, there is a small IC called U2301 on iphone 6 motherboard that is responsible for giving the tension that allows both cameras to work. Is near the camera connector and covered with black glue but I'm linking a picture to show you where. You should check if you could have damaged it while removing the lcd, digitizer and camera connector on the board. Bye.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
i also had the same issue and the motherboard component wat at fault which i got replace, brought he new from here at ifixit and its working like a butter now
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
@lissacoffey which component did you replace?
댓글 달기
Hi Manuel
Can you check if there is any damage on the connectors on the motherboard, or perhaps component on the motherboard is broken?
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Which component could it be?
I am not sure which component can be (I am not as good as some people around here), but if something is missing from the board this mean something is wrong :)
댓글 달기
귀하의 답변을 추가하세요
Manuel MajorFox 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 108
