주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
질문 마감됨
iPhone constantly searching for carrier (no service)
I have this iPhone with a badly broken screen. The lcd still works. The phone is not bend so the motherboard looks ok. Only problem is the phone keeps searching for carrier. what could be the problem?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
First, check the time and date is correct, as this can cause this issue.
Second, check that the IMEI and Modem Firmware is visible in settings. If it is not, you have what's called a baseband issue, and the device needs board level repair. There's a link on my profile for a website of trusted techs if you wish to find someone close to you.
If both of those things are OK it may still be a board level issue (iphone 6 are very common for cellular IC fractures) but it definitely needs to be investigated further by someone experienced
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 4
전체 시간: 223
