주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Sony Vaio VGN-NW240F is part of the VGN-NW series, which was released in 2009 and comes in various colors. The laptop has a 15.5” (1366x768 resolution) display with an built-in webcam and a compact ten-keyless keyboard.
Diskpart clean wiped all the data?
I just did a diskpart clean during windows install and i accidentally wiped all the drives and when i restarted the pc it said 'operating system not found' seems like i have wiped off the OS as well. Though, i have backed up all my data on a 500 gb external hard drive some time back. Can i install the OS from the external drive (on which i have backed up data)? If yes then what's the procedure to do that?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
This is possible if you cloned the drive . If you just backed up your data that does not include the OS then no you cannot. You will need to reinstall a new OS . You must have realized that when you run the diskpart command in the command line it formats the drive tis is to prepare for a fresh windows install. Did you kill the recovery partition as well?
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Saurabh Gulati 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 24
전체 시간: 241
