주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
494 질문 전체 보기
Keyboard glitches out and trackpad doesn't work
Hi,
I am having some issues with my MBPr, The trackpad all of a sudden stopped working and the keyboard glitches out. I restored the computer to factory default, it did not help. Is the issue most likely the keyboard connector and trackpad connector disconnected or could it be that the whole top case was ruined somehow?
Thanks,
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Check it for a swollen battery.
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
And you tell me to explain the problem even more and put links and stuff yet look at your answer
The irony here makes me smirk. :)
댓글 달기
Expanding on @Mayer's answer, there's a valid chance that it's a swollen battery, or a faulty Trackpad.
CoconutBattery 3.3 is the current version, and it's a good tool for assessing battery problems.
http://www.coconut-flavour.com/coconutba...
iFixit's Guide to 2014 Retina Battery Removal:
MacBook Pro 13" Retina Display Mid 2014 배터리 교체
First, use that program and see if "Service battery" or anything other than Good is listed. Design Capacity should be high, too.
Second, as a diagnostic, open your retina and loosen the battery screws as much as you can, relieving any pressure from a swollen battery, and see if the trackpad gains some sanity. If it does, time for a new battery. If it doesn't, it's a trackpad.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Obviously I'm going to have to do a guide on how to get this battery out in a quarter of the time the iFixit staff does it.
that's why we're here, right? :D
PS, I voted your answer as helpful; though short, it was the best concept.
댓글 달기
귀하의 답변을 추가하세요
Masoud Harati 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 389
