주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Only accepts certain chargers and drains battery quick
Hi,
I have a 5s that was returned by a customer. Originally he bought it and messaged me saying it was completely dead, I went to his house and tried a different wire and then he told me to change the battery anyway as it was draining fast. I changed the battery and the same thing happened again except the other wire didn't think this,
I disconnected/reconnected the battery and it turned on (with 80%+ battery) so I am thinking maybe it wasn't connected right.
Now I have the phone back and I have refunded him and I am doing more tests. The phone doesn't charge with certain chargers, I have a 5c that charges with all of them. I'm unsure of which are genuine and which aren't but I believe it won't charge to genuine ones
The battery drains fast in standby mode
Is this damage from using 3rd party chargers? What can I do to fix?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
What apps does he use on his phone? Have you checked charger port if there's any build up of dust / debris? If there is, use a toothpick to clean out the charger port, because if the lightning charging cable does not plug in fully into the port, some chargers will not charge properly.
It's surprising that sometimes a blocked up charger port can actually cause a phone to short and drain power.
For example, on a samsung phone, it would brick the software because pins were probably bent and shorting on boot when the charger port was blocked. Once I cleaned it up I had to reload the firmware (software / operating system) on the phone to get it working.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
The phone has been reset with no apps. The charger port is clean
댓글 달기
귀하의 답변을 추가하세요
James Carter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 6
전체 시간: 250
