주요 콘텐츠로 건너뛰기
This is the HP Photosmart Premium e-All-in-One Printer. Model Number: C310a. Product Number: CN504A.
24 질문 전체 보기
It won't print its got ink it just won't print why
Please can anyone help me my printer won't print its got new ink and it works but when i press print on my computer the printer turns on it looks as if its printing but when it spits it out the paper is blank why?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
Hi,
Just curious, does it print OK if you make a copy of a document, using the control panel of the printer? If it does what OS is installed in your PC?
댓글 달기
답변 1개
가장 유용한 답변
It sounds like the head is blocked. Are you using aftermarket inks? as this can cause damage to print heads (which is almost irreversible without replacing the head, which is so expensive buying another printer is often a batter option)
Assuming you are not using aftermarket inks, or that this happened after a warm day or a period of sitting, try doing a head clean.
This can either be done via the printers menu or via printer properties on the computer. It sometimes needs to be done several times. More information here:
http://h30434.www3.hp.com/t5/Inkjet-Prin...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Claudia ordonez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 451
