주요 콘텐츠로 건너뛰기
Sony’s 20.1 megapixel camera designed to capture still images and video recording. Model number: DSC-W800.
12 질문 전체 보기
Why will my device not power on?
Why won't my Sony Cyber-shot DSC-W800 power on? When pressing the power button nothing displays on the screen and the device seems to be unresponsive.
Could this be a battery issue or something more serious that would require repair?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
يرجى توضيح أكثر هذا قليلا
@tcampo what happens when you do replace the batteries? does it then turn on?
댓글 달기
답변 1개
선택된 해법
There may be several reasons why your device may not be powering on. Following are the common ones:
  • The battery may not be sufficiently charged. It may discharge automatically if not used over a long period of time. In this case, simply charge the battery. Also, check to make that the battery is inserted in correct orientation.
  • The battery terminal may not be clean. You may clean the terminal with microfiber.
  • External temperature also effects the way the camera functions. Thus, make sure to not use the camera when the temperature is above or below 0-40° C. Condensation might occur if the camera is moved from extremely cold temperature to a warm environment, which could prevent the camera from functioning properly. In that case, let it come to room temperature and allow the condensation to evaporate naturally.
  • For more information, refer to the troubleshooting page.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Thomas Campo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 19
전체 시간: 1,537
