주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair and troubleshooting information for the Suzuki FA50 Moped.
Unit does not start
The unit has been sitting for 6 years. I cleaned carb--has great spark and 60psi compression. Put in Fresh Fuel-Has enough oil, Still does not start--any ideas 1986 Suzuki FA50
Update
Not even a hint of starting. However when the spark plug is removed we get a puff of air/compression from cylinder. Very little gas if any on spark plug no matter how many times you kick start it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 2개
what does it do when you try to start it?
Do you have a spark?
댓글 달기
답변 1개
가장 유용한 답변
Sounds like you have carb problems, or a reed valve problem. First things first, unplug the fuel line and make sure the petcock is working. Next clean the carb, make sure all channels and passages are clean, finally check the reed valve condition.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Paul Allan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 12
전체 시간: 2,102
