주요 콘텐츠로 건너뛰기
LG G3보다 작고 저렴한 LG G3 Vigor, 2014년 9월 출시.
Why won't my phone turn on?
I just tried to turn my G3 Vigor on and nothing happened. What should I do if it won't turn on?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 7개
가장 유용한 답변
Make sure that the phone is charged. It won't turn on when the battery is uncharged, so you need to plug the phone and charge it and see what would happen.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Loose the phone,
Heat the board with solding paste( flux)
Let it get cool and jail the phone back.
Good luck..
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi Jared,
Check out this troubleshooting page for the LG G3 Vigor. If you're still having trouble with your phone, comment back with some more details about your issue ( Age of your phone, what solutions you've already tried, ect. ) and we'll continue to try and help. Good Luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
1. Check the battery
2. Check the battery sensors
3. Make sure the power switch has water or other deposits
4- Activate the device using the material of the frying and heating a light at 350%
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The reason for the sudden shutdown of the phone during use and battery is charged 100% without any external cause
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Alexa will not answer
이 답변이 도움이 되었나요?
점수 0
댓글 달기
  • Make sure the battery is fully charged
  • Check if the charger is working properly
  • Check for the moisture on the phone
  • Boot the Nexus 5/5x in Recovery mode(Worked for me)
  • Go to the authorized repair store to fix the hardware issue
Source : https://fixyourandroid.com/fix/how-to-fi...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jared Stickl 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 418
