The hammer follows the Slide forward when fireing
How do I fix this problem?
좋은 질문입니까?
This can be caused by several different things, ranging from damage to the sear or hammer spur to worn leaf spring to a bad trigger job. If you could provide more info I could help more.
이 답변이 도움이 되었나요?
Hi Darrel,
Follow down is most likely caused by negative sear engagement and/or not enough sear engagement. I recommend taking it to a trusted gunsmith to have it fixed. Shameless plug, I am a gunsmith at J&G Gunsmithing, so you can contact us about sending it in for repair. Let me know if I can be of more help.
이 답변이 도움이 되었나요?
check out the hammer and sear engagement notches; if all looks like no one has messed with it, replace the sear/disconnector/grip safety flat spring. Then test with two rounds in the magazine until it proves itself.
지난 24시간: 0
지난 7일: 2
지난 30일: 35
전체 시간: 747
