주요 콘텐츠로 건너뛰기
모델 M7572 / 400 또는 500 MHz G3 프로세서
45 질문 전체 보기
airport card for Pismo
I want to put an airport card into my 400 MHZ G3 Pismo. Is this possible? What kind of card and where can I find one?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
Here's the iFixit guide to adding an Airport card to the Pismo: PowerBook G3 Pismo Airport Card Replacement
And here's the recommended card: [연계 제품이 누락 또는 비활성화 됨: IF143-010]
When I wanted to give my old Pismo wireless capabilities, I ended up buying a PCMCIA card instead of an Apple Airport card -- it was just much, much cheaper. The minus is that you have the end of the PCMCIA card jutting out of the side of the computer. The bonus is that it *might* get better reception than a card that's internally installed.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
The Airport card is the most trouble-free solution, but they can be expensive and hard to find. I'm glad ifixit has them.
Alternatives are the PCMCIA card ones, as mister790 suggests; there are also USB/wireless adapters, but I dunno if they'd work with the system the Pismo is running. The USB solution (and some of the PCMCIA cards, I think) means dinking around with drivers and connection apps that are workable but a pain to use.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Pismo is USB 1.0 so the USB/wireless adapters would not be recommended but the PCMCIA cards work very well. I remember that I installed a Belkin card that used the broadcom shipset, the signal was pretty good and the card used the airport software just like the Apple original card.
댓글 달기
I placed an order, No. 129719 and now need to cancel it. Please cancel and notify me.
Thank you.
Mikekeable3@gmail.com
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
This probably isn't the best venue for that kind of communication. You should probably contact Customer Support in the Parts Store instead.
댓글 달기
귀하의 답변을 추가하세요
mikeable 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 2,553
