주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
The engine cranks but no spark?
It would crank but not spark so I got a new battery, changed distributor cap, plugs wires, ignition coil and button under distributor still wont start.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Im having the same problem.. Working on a friend's 98 GMC K1500 5.7 4x4. He said he moved it to it's current spot. Went to move it next morning and nothing.
I only charged rotor for distributor and coil. At that time I didn't have my test light or multimeter. I got my test light came back the next day check the voltage at the coil it's getting 12 volts in the voltage regulator I guess it is in the front of the coil or side of it and then the new coil is getting power but it's not putting power out they're both at 12 volts at the plugs and recommendations?
@jeremyyoun78592 just to clear things up. It has no spark when you crank over corect? You have 12V at the coil but no sparks at the plugs,correct? What do you mean by this "they're both at 12 volts at the plugs"? Have you checked the crank shaft sensor? Have you checked the ECM fuse under the hood fuse box? Does this beast have an anti theft device? Did you check that?
댓글 달기
답변 2개
선택된 해법
Are you just randomly changing parts or are you trying to chase down where your spark stops?
work backward from the plugs . No spark next go back to the distributor cap if there's no power there go back to the coil. is there power going in if so go back to the distributor and check the modules in the base of the distributor. check the wires going into the modules. If there's no power at the coil follow your wires back to find power . There could be a short in the ground wire or a short in your power line in .The may be a problem with the ignition switch . Using a test light can help track your power. Hope this helps
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
Ignition switch was messed with how do I know if it's working or not
The ignition was tooken apart when I bought the car I tried to put it back together I dont know if I put it back corectly. Bottom line is it won't start it will crank, sounds kind of whiny but roufh. There are other factors for the mousy part I replaced the spark plug bought some relays. Hoping it would solve the problem but it sounds the same when trying to start it. It's like I haven't phased any thing I need help.
Anyways maby your not getting any fuel. The reason and why I say this? Everyone is pressing on to me about it. Hope I gave e you an anwer.
댓글 달기
1 minute ago by Ground'E
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
bobbycl1984 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 95
전체 시간: 6,092
