주요 콘텐츠로 건너뛰기
The Honor 3C is an Android smartphone produced by Huawei and released in December 2013 for 3G, April 2014 for 4G, and August 2014 for 3C Play. The Honor 3C can be identified by model numbers H30-T00 and H30-U10.
Call log does not show in huawei 3c
Call log does not show in huawei 3c from 3 days ago. Older call logs are ok but new one is not shown or saved . How can i fix it ?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
Is your internal storage space running low on your phone? Is your date and time correct?
댓글 달기
답변 5개
가장 유용한 답변
Hello geor geor ,
just correct date, time and time zone. your issue will be fixed automatically.
Note : actually call logs updating according to system time. scroll down and you may find newly received calls log info on bottom & you will received an error "security certificate error " when you begin to surf internet. after re-correct date and time both issue will be solve
Cheers!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
If you have a Google Account on the device remove it. Test the call logs. Re add.
That should do the trick!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have Purchased Honor 3c in before 1.6 years back ...after within 1 month my phone got water damaged..after clean it I have face Problem for Charging ..Charging while my mobile battery not charged it's saw Charging but no charged ...I saw to Service center they Told inside some IC cmos has problem & u need to change new Mobile PCB board....They told PCB cost around 7 k& my mobile was 11 k..Than after till date I have used my phone by external I don't have any problem for day to day use..but I needed to charge battery by external.. If anybody know person who know to repaired my problem.. I m very thankfully ..I loved this phone..
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My honor 3c phone keeps on popping up "unfortunately android.contacts had stopped" the contacts,dialer and messaging apps have changed to the android logo. May I know how to solve this problem?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My Huawei Honor 3C Mobil Contact not working sometime what is the soluations
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
geor geor 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 3,642
