주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
질문 마감됨
Flashlight and camera flash not working
Front and rear cameras work but neither of the flashes work, nor does the flashlight work/light up.
Update (03/11/2016)
Not sure which parts would correct the issue.
Update (03/11/2016)
I turned the flashlight on but it did not work. I left it on and began lightly tapping the corner on my palm and the light came on and continues to work. Camera flash is now working also. The connection must have been loose.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi Phil,
Glad you could get that sorted out quickly. If this ends up becoming a persistent issue in the future (which I hope it won't) I would recommend that you investigate the upper component cable. This area powers the flash "bulb" in the iPhone.
iPhone 5c Audio Control and Power Button Cable Replacement
Rather than purchase a new phone you could also try purchasing a housing assembly with genuine parts and either swap the cable out or perform complete parts transplant from the old unit to the replacement housing (if you feel daring enough) =)
Hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,697
