주요 콘텐츠로 건너뛰기
Black & Decker 7.2V Lithium Cordless Drill/Driver. Eleven Speeds with a non-removable battery.
3 질문 전체 보기
Why is my drill not charging?
I just bought my drill a few months ago, I went to use it today after it has set for a while and it wont drive my screw. I keep it plugged in over night before I know I am going to use it. Is it possible that I killed the battery? The drill has worked great up until now. Even with hours of charging the battery dies after three screws if I'm lucky.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 7
댓글 달기
답변 2개
가장 유용한 답변
Hey Ray,
It sounds like it is possible that you have overcharged and damaged your battery. This drill's charger is not a trickle charger so leaving it plugged in will damage it. Luckily there is an easy fix. Check out our troubleshooting pagefor replacement guides.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
The link wasnt much help. When I put dead battery on to charge. Green light flashes once and red stays on and not charging.. And ideas?
댓글 달기
I’ve had problems sourcing replacement charger for Black and Decker 12 volt battery. Today I hooked the battery up to a small solar panel 12 volt charger and it has come alive! Put the positive clip onto the large side panel and the other one into the clip on the other side and away it went. John
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ray 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 10
7일 전: 45
30일 전: 211
전체 시간: 28,054
