주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
질문 마감됨
LCD is a fake or not?
Hi guys.
I have two iPhone 5S, and one was repaired. Looks like that someone from repair-service changed a LCD panel to another one. Because now I see that proximity sensor is a blue color. From some web-sites I see that proximity sensor cover is missing. Camera is not centered and has a dust. Small window on left side from camera has a different size (mine has a smaller).
Photo of my both iPhones 5S:
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
I can't see the images will you please upload them right on here
댓글 달기
답변 1개
가장 유용한 답변
OK, that is normal. I've changed many iPhone 5 and 5s screens before. This usually happens depending on if the screen comes with the front camera holder plastic cover preglued to the LCD to make the camera sit flush with the front display assembly glass camera hole.
Another way is that the plastic front camera holder is taken from the previous one and aligned so that it looks like it's centered as close as possible. This isn't something too much to worry about as long as it isn't making the front camera photos bad.
Not all new iPhone 5 / 5s screens come with a preglued front camera plastic holder for the display assembly.
You can open the phone and use cotton bud to clean the front camera glass and front camera lens if you want by following this guide:
iPhone 5s Front Facing Camera and Sensor Cable Replacement
Since the screen has been fixed before, it should be easy to get the front camera flex out as it won't be glued to the display assembly, but still you should follow the guide if doing so. The step where you need to heat it up is not required.
Does the phone screen go dark when taking calls and putting the phone next to your ear? If not then the proximity sensor has gone faulty.
For that blue proximity sensor, I don't think I've seen that before and is probably due to the quality of the front display assembly glass. But then again nothing to worry about if the phone is functioning perfectly fine. You are probably right, the rubber gasket for the ambient light sensor is probably missing.
Here are some examples of what the front camera flex contains:
iPhone 5s:
iPhone 6:
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks for that great answer! As result: do you think that it is original display?
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,085
