주요 콘텐츠로 건너뛰기
A compilation of guides for counter-top and handheld blender repair.
346 질문 전체 보기
stripped gear connected from the base of the blender to the pitcher
My Ninja blender 10100 watt model BL700 30 will not blend when I have something in it but will spin when it is empty it will not even blend ice cream I believe it is stripped in the base gear or whatever you call the gear looking thing in the bass that connects to the picher.. apart to get it off an epoxy it or something but I can't figure out how to get it off
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
Do not dispair. The stripped gears can be repaired by replacing the 3 small gears and just a small amount of enginuity. https://sites.google.com/site/dgeake51/h...
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
How i can find thes pices tank you
Go to this site: https://sites.google.com/site/dgeake51/h.... Step by step instructions.
댓글 달기
Your blender has stripped planetary gears.
It's shot. Toast. Too hard to fix.
Why? 1. No easy parts suppliers. 2. Hard to disassemble when the gears are stripped because you can't separate the motor from the gears.
Ninja put in cheap (non-metal) plastic planetary gears in these units. They work ok for most things, but not for ice crushing drinks. While they put the motor mounts on rubber supports, and the drive connection to the base of the blender is rubber, these do not protect the gears from easily being overloaded with the large multi blade pitcher when it is full of cold (hard) ice.
They need to warn people who buy this for ice blended drinks to fill the blender only half full of ice. It's not strong enough to handle a lot of full-pitcher ice drinks.
Mine broke on the fifth pitcher.
They know about this problem, as you only need to search for it in Google. But why is it not fixed? Why is there no recall? Why does Costco carry it in view of their QC policy?
I don't know, but someone should sure get going on this problem I think.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
the plastic gear is cheap, bad design, they should have never made the gear out of plastic. throw it away and buy a new one
Where do you find the gears? I need to replace the planetary gear, but can't seem to find those kind of parts online.
댓글 달기
귀하의 답변을 추가하세요
allenmc503 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 72
전체 시간: 7,344
