주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
Home button is stuck
I am trying to fix my ipod touch 5th generation and wondering how I fix a home button that is stuck down. What part do I need?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
thanks - a great help
댓글 달기
답변 2개
가장 유용한 답변
Enabling the Alternate Home Button
1. Open your iPhone’s Settings. If your Home button is not working, you can add a replacement Home button to your screen that appears in front of the apps you are running. This button will allow you to mimic the functionality of your non-working Home button.
> You can find the Settings app on your Home screen.
> If you can’t access the Home screen because your Home button is stuck, you can turn off the phone’s power and then turn it on again.
2.Tap General. In the General menu, find the Accessibility option. Once you are in the Accessibility section, scroll down and select AssistiveTouch. Toggle the slider to ON. A new button will appear on your screen.
> You can drag your alternate Home button to any position on the screen that you would like.
3.Press your alternate Home button. When you press the button, you will see four options appear. You can access Siri, your Favorites, your Device settings, or press Home to mimic the Home button and return to your Home screen.
> This method is available for iOS 5 and later.
이 답변이 도움이 되었나요?
점수 5
댓글 1개:
thanks = a great help
댓글 달기
How can I Fixed my home Button when it’s stuck?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
skyler hansen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 18
전체 시간: 2,565
