주요 콘텐츠로 건너뛰기
1.5 Core Solo, 1.66 또는 1.83 Core Duo, 또는 1.83 또는 2 GHz Core 2 Duo 프로세서
142 질문 전체 보기
Mac mini A1176 1,83 , 2x512Gb no video, no sounds.
I have good 3 sticks ram.I insert any stick in 1 slot and mini Ok. If I insert second stick in 0 slot mini not working, if insert only one good stick in 0 slot mac no work- no sound only noise fan and cd ,no flash light . is it fatal ?how repair ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
RAM ports do fail. Put the largest stick in the known working slot and just go on. I've seen a couple of reports of smaller RAM chips working in the failed port so I would try it with the smallest chip you have, there's a small chance the this might work. Be sure the slot is clear of debris and blow it out with canned air.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thank you for your answers, but I would like to know because of what can go wrong in the slot to remove the cause.
I had already seen two such breakdowns with Apple products.
댓글 달기
귀하의 답변을 추가하세요
drova 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 1,537
